We are still using version 2017.2, because otherwise we can no longer authorize with smart cards. Is it still possible to connect Adaxes with Azur?
by (170 points)
Hello Johann,
What exactly do you mean? Could you, please, provide us with all the possible details? If you cannot post the details here, you can send them to support[at]adaxes.com.
You can register your Microsoft 365 tenant in Adaxes. This will allow you to assign Microsoft 365 licenses to users and manage mailboxes in Exchange Online via Adaxes. To register your tenant:
  3. Navigate to Configuration/Cloud Services and select Office 365.
  4. In the Result Pane on the right, click New.
  5. Follow the instructions in the wizard to register your tenant.
The following tutorial might also be helpful: https://www.adaxes.com/tutorials_ActiveDirectoryManagement_ManageAndAutomateOffice365.htm.
what version of powershell is needed with modern auth and connect to 0365/azure
asked Sep 30, 2022 by sra98a (120 points)
I need to know what are the latest improvements in Adaxes to work with Cloud automation? Is there any more planned improvements for the Cloud base automations?
asked Apr 20, 2020 by kanishka.silva (40 points)
Hi , I would like to know that is there any API service, where we can work on objects inside Adaxes tool? Preferbly REST API?
asked Nov 6, 2019 by Anil (20 points)
Recently, Microsoft deprecated use of the remote PS sessions using version 1. We have since converted all of our scripts to version 2, but our nightly staff ... { # Close the remote session and release resources Disconnect-ExchangeOnline -Confirm:$false }
asked Nov 2, 2022 by MShep (80 points)
3,346 questions
7,779 comments
544,979 users
