I have a report that has a Multi-valued field of "Other-Login-Workstations". It only displays one of the values in the report.
My report has the following fields:
Name, First Name, Last Name, Department, Description, Password Last Set, Other-Login-Workstations
How do I go about displaying all the values of "Other-Login-Workstations"?
by (1.4k points)
This behavior is by design for multi-valued properties as only a single value can be present in a report column. As a workaround, each user can be added to the report multiple times where each report item of the user will have a different value in the Other-Login-Workstations column while the other columns will remain the same. If this approach meets your needs, please, provide us with all the possible details regarding your report. If it is generated by a script, please, post the entire script here or send it to us (support@adaxes.com) in TXT format.
Ok, I will email you the information, thanks.
Thank you for the provided details. Please, have a look at the following script from our repository: https://www.adaxes.com/script-repository/multi-valued-property-values-s612.htm.
Is it possible to remove the default blank option that shows up in a multi-value field? When I add two possible options for a multi-value field in the Property Pattern constraint, ... along with the other two options. Is it possible to get rid of the blank?
asked Mar 8, 2017 by sdavidson (730 points)
I read the article on using a business rule to automatically set certain field values such as address based on the value of the Office field. Is there any way to do ... on the Office field so the user has immediate feedback and can change it if necessary.
asked Aug 15, 2016 by jscovill (110 points)
We have a New User action set up for our HR staff to use. There is a field in the custom form that states "Notes for IT Department". I want to display the data that is ... IT Helpdesk. I don't know what parameter this would be considered. How can I find out?
asked Feb 14, 2020 by slowllama (100 points)
the following script works great to email a table list of ALL users indicating the appropriate value of the customer fields specified. The challenge is the export ... SendMail($email, "Annual Required Security Audit: SWE", $null, $bodyBuilder.ToString())
asked Aug 20, 2014 by mpaul (360 points)
I am upgrading to version 2013-2 and I have found an issue with default field values. I'm hoping you can assist me with this. Web Filtering Level is associated ... recognized: Also note that one of the custom fields hints data bleeds into the field value.
asked Dec 12, 2013 by BradG (950 points)
3,346 questions
7,782 comments
544,982 users
