We're currently running Adaxes 2016, upgrade is planned but not within the next couple of months.
As per the below KB MS are deprecating TLS 1.0 & 1.1. Does Adaxes 2016 utilise 1.2 to communicate with Office365? https://docs.microsoft.com/en-us/troubleshoot/azure/active-directory/enable-support-tls-environment
Thank you in advance. Gary
by (490 points)
by (270k points)
Hello Gary,
In your version, Adaxes uses MSOL cmdlets and the cmdlets themselves determine what TLS version to use. According to Microsoft documentation if all the updates are installed, TLS 1.2 should work just fine. However, we recommend you to check this point with Microsoft support team.
Thanks very much for the answer, will do
Hello, related to my previous question: https://www.adaxes.com/questions/10919/hi-does-adaxes-2016-use-tls-1-2 In Adaxes there is the Cloud Services section that uses Office365 ... want to make sure we've covered as much as we can. Thank you again! Gary
asked Jun 15, 2021 by gazoco (490 points)
We are in the process of updating our Active Directory Domain Controllers to server 2022 and the Domain/Forest function level. Our concern is that we still have Adaxes ... version of Windows server for our DCs and the Domain/Forest function level of 2016?
asked Oct 11, 2023 by sphoeinix (20 points)
The individualmodule for PnP if upgraded to 2.2 in non PowerShell 7 breaks in Adaxers. Previous versions of Powershell will not allow the 2.2 PnP version to connect which is ... to make this work but if it is deprecated by MS, then we will lose functionality.
asked Aug 16, 2023 by nick.boehm (20 points)
Hi there, we have some custom commands that need the enter-pssession with -sshtransport which is only available in PWSH7. Is it supported to install powershell7 right on the adaxes server? Kind regards, Constantin
asked Mar 3, 2022 by Constey (190 points)
Can you point me to documentation to upgrade from Adaxes 2019.2 ver 3.1.2.174230 to the current version please?
asked Jun 16, 2020 by msylvester (60 points)
3,326 questions
7,727 comments
544,683 users
