Is there a way to send an email notification when a user is added to a group dynamically (with LDAP filter) , it's work only when i add the user manually
Thank you
by (70 points)
What exactly do you mean by added to a group dynamically (with LDAP filter)? Could you, please, describe the desired workflow in all the possible details with live examples?
For example, i have a group "test" users are provisionning by a rule : (physicalDeliveryOfficeName=Paris). I have create a worflow for send me an email when a user is added to that group and i don't receive anything, but when i disable (physicalDeliveryOfficeName=Paris) and add a member manually i receive the notification...
reshown by
Thank you for clarifying. Unfortunately, there is no possibility to trigger business rules when membership in a rule-based group is updated based on the specified criteria. As a solution, you can use a scheduled task that will do the following:
  • Send email notifications to group members and mark the users (e.g. by setting a custom Boolean attribute to True).
  • If a user is marked and is no longer a member of the group, the mark will be cleared.
Finally, the scheduled task will look like the following: image.png
asked Jun 30, 2021 by RayBilyk (230 points)
Hello, we offer our team leads to manage their teams: - the manager select "My Team" - then all member of the team are listed - the manager selects a member of the team and ... by") :o How can I set such a filter which restricts the groups? Many thanks, Horst
asked Mar 23, 2018 by HorstR (460 points)
Hello, I'm trying to setup a business rule that will send an email to the user when they are added to a group. Under the User Object I don't have an option to Launch ... to get the new group member's email address so I can send a notification to it? Thanks!
asked Dec 1, 2015 by drew.tittle (810 points)
3,346 questions
7,782 comments
544,989 users
