by (300 points)
by (270k points)
Yes, it is possible. You can use the built-in All users report. By default, the report is located in container Reports\All Reports\Users. For the report to include a custom attribute, add the corresponding column. To export the report, right-click it, point to All Tasks\Export and click Entire report. image.png
We have users with group memberships in multiple domain. All groups are type Universal. For example we have DOMAIN A and child domains for each dept, such as ... group memberships during user account copy, including memberships from other domains? Thank you,
asked Sep 10, 2020 by maliguinem (20 points)
If I have created an custom command i would like to find where this CC is used (linked) in Adaxes (used in Scheduked Task and so on). How can a general find references ... report where I can find all the Linked Objects that I have created by myself in Adaxes ?
asked Jun 1, 2023 by Beat Ott (40 points)
Like remove all users from full access other than User1, User 2, & User3?
asked Oct 29, 2019 by hgletifer (1.3k points)
3,326 questions
7,727 comments
544,681 users
