This is for license purposes and we do not want them visible in the Adaxes portal.
Is it an AD attribute being used or an Adaxes custom one? Should all users with the attribute filled be added to the unmanaged list or only those with the attribute set to a specific value?
Any additional details and live examples of the desired behavior will be much appreciated.
It is an AD attribute, and all users with the attribute set to a specific value should be added to the unmanaged list. For example, all users with the serviceUser attribue set to Yes should be unmanaged.
Thank you for specifying. Have a look at the following script from our repository: https://www.adaxes.com/script-repository/add-users-to-unmanaged-list-based-on-ldap-filter-s645.htm.
I am trying to see if I can implement this in Adaxes somehow to support role-based provisioning to external apps (using appropriate Powershell scripts) but struggling to work ... to invest in a full-blown role-based provisioning platform (would rather not!).
asked Dec 24, 2019 by Bernie (310 points)
I am basically setting up the self service portal to only allow a user to reset thier own passwords.
asked Oct 19, 2022 by mightycabal (1.0k points)
3,343 questions
7,766 comments
544,953 users
