Hi
Does the built-in audit feature of Adaxes also track changes NOT made via Adaxes? For example via the usual AD management console?
Thanks and best regards!
Marius
by (50 points)
Unfortunately, there is no such possibility. Adaxes can only log and track the operations performed in it.
Thank you for clarifying!
asked Nov 8, 2022 by GronTron (270 points)
We were used to bind to group member object using: $member = $Context.BindToObjectByDN("%member%") which worked perfectly, but now it is not. Its because %member% is returning ... ? And is it possible to get DN of added/removed member using another variable?
asked Sep 14, 2020 by KIT (910 points)
Hello, Is there a built in method for checking user accounts that have expired in Azure?
asked Jul 31, 2023 by Homelander90 (330 points)
asked Apr 14, 2023 by mightycabal (1.0k points)
We can authenticate if we login to the machine hosting the service but if I have the client installed on my desktop, I can't authenticate with any ... .com/en-us/windows-server/security/credentials-protection-and-management/protected-users-security-group
asked Sep 12, 2022 by mark.it.admin (2.3k points)
3,346 questions
7,781 comments
544,981 users
