I would like to change department without a script just yet if possible on multiple accounts.
If I cant do this then I will entertain custom script
by (350 points)
There is no need to use scripts. In Adaxes Web interface it can be done using a custom command. You can select all the necessary users and then click the command on the left.
Also, it can be easily done in Adaxes Administration console without the need to perform extra configuration steps:
  1. Select all the users you need (e.g. using search).
  2. Right-click any of the selected users and then click Add/Modify Property in the context menu. image.png
  3. Select the Department property.
  4. Click Next.
  6. Click Finish.
How can I allow manager of distribution group to edit just email aliases (proxy addresess) of that group? Not the primary SMTP address.
asked Nov 19, 2019 by KIT (910 points)
I am basically setting up the self service portal to only allow a user to reset thier own passwords.
asked Oct 19, 2022 by mightycabal (1.0k points)
When using the administration console (not the web console), we would like to be able to customize the fields that are shown on the different tabs of the user properties ... in the web interface but I don't see the same option for the administration console.
asked Jan 27, 2020 by abarker5 (80 points)
3,346 questions
7,782 comments
544,981 users
