When an approver approves or denies an approval request, they are prompted for a reason, but this field can be left blank. Is there a way to make this field required?
by (320 points)
Unfortunately, there is currently no possibility to make the field required. However, thank you for the suggestion. We forwarded it to the corresponding department for consideration.
Got it. Thanks for your quick help!
A little bit of context: There are 3 departments that share 1 Active Directory. Now each department has its own OU. I would like to have an email sent when a user is ... if this is possible without Powershell? If not, is there a pre-existing script for this?
asked Oct 3, 2023 by Cas (150 points)
We are testing Windows Autopilot and would still like to use the adaxes client to allow for SSPR. Is it possible to configure the Windows Integration settings on a machine that is not domain joined but is joined through Azure AD?
asked Sep 3, 2020 by scoutcor (120 points)
3,346 questions
7,782 comments
544,986 users
