Hi Support-Team,
our Log Databases actually runs on SQL DB in Compatibility Level 100 (SQL 2008), we'd like to raise the level to 130 (SQL 2016). Is that possible without any issues or is there anything that needs to converted or adjusted?
Thanks Markus
by (130 points)
Hello Markus,
There are no requirements from Adaxes about upgrading your external SQL Server. However, we would still recommend to make a backup of the database beforehand.
I'm probably not looking in the right place but is ADAXES (current version) compatible with IE11? Thanks!
asked Jan 15, 2016 by VTPatsFan (610 points)
Do you have a browser compatibility list? For example, is Chrome fully supported for ADAxes? Thanks
asked Aug 22, 2013 by BradG (950 points)
We are in the process of updating our Active Directory Domain Controllers to server 2022 and the Domain/Forest function level. Our concern is that we still have Adaxes ... version of Windows server for our DCs and the Domain/Forest function level of 2016?
asked Oct 11, 2023 by sphoeinix (20 points)
Hi I've created a new adaxes configuration and limited access to do things based on the 'actions' section: only create, modify, delete contacts are available. Added myself to ... since updating to version 3.16.21408.0. How can I resolve this error? Thanks
asked Oct 4, 2023 by cheezoid (20 points)
First off I have to say that Adaxes is really extraordinary and has been such a massive help to delegate a lot of the day-to-day AD management across mutiple untrusted forests. ... how it functions under the hood, and a lot of SDK documentation left to read.
asked Sep 27, 2023 by McMyers183 (20 points)
3,346 questions
7,782 comments
544,990 users
