I'm wondering if there is something like the calculated property "%adm-RandomString%", but that also includes symbols. Is there another command that accomplishes this task, or is there any way to modify how the %adm-RandomString% generates it's characters? Any way I could get this done within the realm of Adaxes?
by (70 points)
Unfortunately, there is not such possibility using Adaxes built-in functionality. However, we forwarded your suggestion to the corresponding department for consideration.
Hi Support, I'm trying to use adaxes to send a couple of branded emails with User information such as UPN and First name. I've written some HTML email code but would ... <table class="wrapper" width="100%" cellspacing="0" align=center cellpadding="0">
asked Feb 18, 2020 by richarddewis (260 points)
Before Deactivation of an Account on the Webinterface our Help Desk need to change the AD User Description manually. Is it possible to force a manual change before deactivation ?
asked Feb 7, 2020 by lv01 (20 points)
Hi, is there possibility to search some custom string across all powershell script files used in Adaxes? I.e. Custom commands, Scheduled tasks etc I need to find out where is used some PowerShell command to be able to replace it for another one..
asked Apr 27, 2020 by KIT (910 points)
3,347 questions
7,787 comments
545,035 users
