With Active Directory Users and Computers, I can add group members by copying a list of usernames and pasting them into the Add Members dialog box. This is very quick and easy. How can I do this with Adaxes? It seems that I can only add one member at a time.
by (80 points)
It is a popular request among our customers, but currently such functionality is not available. As a workaround, you can use the following script from our repository http://www.adaxes.com/script-repository ... k-s371.htm. It adds users specified in a certain attribute of a group to members of that group. Users can be identified by their usernames (SAMAccountNames), separated by commas. As for the property that you can use, we suggest using one of Adaxes custom attributes, for example, CustomAtrributeText1. Such attributes are not stored in AD, but can be used the same as any other attributes of AD objects.
For information on how to add the attribute to the form for creating or editing groups, see the following tutorial: http://www.adaxes.com/tutorials_WebInte ... diting.htm. For information on how to change the name under which the property appears everywhere in Adaxes, see the following help article: http://www.adaxes.com/help/?HowDoI.Mana ... Names.html.
I have the ADD TO GROUP operation in my OTHER drop down menu. I can use search or browse to an OU, select multiple users that I want, select ADD TO GROUP operation from the list and select the group I want them all to be added to.
Would that help you?
Would be helpful if the functionality is available to copy and paste multiple users into a group
Definitely.
I'm in the process of creating a Web interface for requesting IT accounts. Upon submission, I want to run a Powershell script that will create an item in a Sharepoint task list.
asked May 14, 2021 by sandramnc (870 points)
usually we have to set up users account with access to many share mailbox. However, the time consuption adding those emails one by one it is too much as we needs to sep up many users in one day and that task can take from 10 minutes to an hour.
asked Apr 29, 2021 by Sandovis (20 points)
asked Jan 16 by dominik.stawny (160 points)
I'm trying to combine these two scripts to effectively store a user's group memberships in customattributebinary5 and then be able to copy and paste those memberships to a ... ) $Context.LogMessage("Added the user to group '$groupName'", "Information") }
asked Jan 24, 2020 by yourpp (540 points)
We have users with group memberships in multiple domain. All groups are type Universal. For example we have DOMAIN A and child domains for each dept, such as ... group memberships during user account copy, including memberships from other domains? Thank you,
asked Sep 10, 2020 by maliguinem (20 points)
3,348 questions
545,054 users
