I would like to use pre-defined security groups
- Domain User
- Authenticated User
- Owner (Managed By)
for the Access Control during the login.
But I have no clue how to define this - all my attempts have failed :(
Many thanks,
Horst
by (460 points)
by (271k points)
Hello Horst,
There is no possibility to use Security Roles to control access to Web interfaces. You need to use Web interface Customization tool. For details, have a look at the following tutorial: https://www.adaxes.com/tutorials_WebInt ... erface.htm.
sorry about my unclear question. :(
I would like to use the mentioned groups in the Adaxes Web Interface.
But I have no clue how to define because of the spaces in the groupnames.
Sorry again,
Horst
Hello Horst,
For the Access Control configuration, it makes no difference whether there are spaces or not. You just need to enter groups in the required format separated by commas. For example:
I already tried these possibilities before - the result was always the same "Access is Denied" :?:
Regards,
Horst
Hello Horst,
Make sure you use values of the sAMAccountName (Group Name (pre-Windows 2000)) property. If you use values of the cn (Group Name) property, Access Control settings will not work.
asked Apr 22, 2020 by RayBilyk (230 points)
I am getting this error. Please help.
asked Jan 22, 2021 by ComputerHabit (790 points)
Hello all, We've upgraded our Adaxes from 2017 - 2018. One of the sub-sites that have been configured is an "administrator" portal. This portal is restricted to ... to rule out nested groups as a possibility. Any help/direction would be greatly appreciated.
asked Jun 25, 2019 by JHA-Matthew (70 points)
Hello, I'm trying to make one AD Group to allow access to one of the Web Interfaces I created. When I add that group to the Allowed list under the access control tab on the ... I don't have to go into the web interface config tool every time we add a customer.
asked Nov 2, 2015 by drew.tittle (810 points)
I'm working on building a Telecom web interface for the telecom team at work. I am only have one issue and that's with access control to change the IP phone number. ... IP phones but my non-elevated account has this issue. Any ideas would be helpful. Thanks
asked May 29, 2014 by 7efd721c8b (420 points)
3,340 questions
7,764 comments
544,924 users
