Is it possible to have a variable or custom field that I could use and reference from multiple PowerShell scripts? For example, I want to have two custom commands, each runs a separate PowerShell script, but I want to call them both as part of a single scheduled task. I would like to be able to leverage a field or variable that I could write output of the first custom command script to and retrieve it from the second custom command script. It could be something system wide or maybe local to the scheduled task?
Ryan
by (920 points)
Hello Ryan,
Unfortunately, there is no such possibility. However, thank you for the suggestion. We will consider it.
First off I have to say that Adaxes is really extraordinary and has been such a massive help to delegate a lot of the day-to-day AD management across mutiple untrusted forests. ... how it functions under the hood, and a lot of SDK documentation left to read.
asked Sep 27, 2023 by McMyers183 (20 points)
I made a custom command that executes a powershell script, if you run the script from the adaxes console, then everything works, but if you run the command from the web interface ... the script, you can see that the value is empty. Am I doing something wrong?
asked Nov 18, 2022 by Alvares (100 points)
I would like to have the possibility to use different icons for AD groups. I have groups for file permissions, applications, mailboxes, etc. For each group type I ... do this without schema extension? or will this be possible in the future? regards pudong
asked May 6, 2022 by pudong (670 points)
As part of our HR onboarding process, they need to specify non-AD integrated software requirements. Is there a way to have a customised field on the form that when ticked or ... say the name of the software and have it linked to a particular field in AD.
3,343 questions
7,766 comments
544,953 users
