The Advanced Search in the Domain Find(CTRL-F3) function allows you to select a custom Active Directory field(added by IT, not a windows default AD field). When you specify the criteria and value for boolean fields it recognizes the field is boolean and limites the search to true or false accordingly. When you press find now... the search results are empty. Since I cannot cut/paste the print screen, here are my Find Settings: Type = User, US Security Processing is the selected field, equals is the logical operator, and true is the value.
Additionally on Custom String fields it would be very helpful to have a Contains, Does not Contain logical operator in the Find function.
by (360 points)
Michael,
Try using the LDAP Search tab. Will there be any search results if you specify an LDAP filter?
Example: (usSecurityProcessing=TRUE)
For string fields those logical operators must be available. Can you right-click your custom property in the Result Pane, select Properties, and post a screenshot of the Properties dialog here?
If I use the LDAP query feature AND the actual Active DIrectory field name AND = TRUE(all upper case) - I get the proper results.
The advanced search shows the "Friendly Name" equals, then the drop down only has two option true and false(all lower case). No matter what I select, neither produces any results.
I would love to put in print screens, but cut and paste into this forum doesn't work for me... please fix that...
Hello Michael,
We've managed to find and fix the issue with boolean search criteria in Advanced Search. Thank you for the bug report!
The fix will be available in 2012.2 that is scheduled for November. If you need the fix earlier, just let me know.
To post an image:
  1. Click the Upload attachment link located underneath the text box.
  2. Choose Browse and select the image you want to post.
  3. Click Add the file to upload your image to the post.
  4. Set the cursor to the position where you want to paste the image, and click Place inline.
Is it possible to have custom command that doesn't execute on a specific (or any) AD object? I realize Adaxes is for AD management, but I was wondering if it would be ... to execute against and AD object, I just need it to talk to the SQL server. Thanks
asked Nov 9, 2012 by bemho (520 points)
I am working with Adaxes for the first time. Looking to set up the service account so it can actually make changes to AD not just to register the Adaxes Service. I would rather ... the Adaxes service. What I am unable to do is have adaxes make changes to AD.
asked Sep 21, 2022 by mightycabal (1.0k points)
Hi I had followed the steps listed under the url: http://www.adaxes.com/tutorials_Simplif ... Script.htm to validate EmployeeID field, to check for "-". How come during ... system still let me create the new user account even though I purposely entered "-" ?
asked Nov 6, 2013 by alextan26 (20 points)
Softerra Adaxes does not extend the AD schema. Moreover, Softerra Adaxes does not store its data in Active Directory and doesn't modify the native permissions assigned in ... Adaxes, you can use Active Directory just as you did before the product installation.
asked Jun 17, 2009 by Adaxes (550 points)
3,350 questions
545,067 users
