Hello
We have a problem with exporting to CSV. Running the "All Users" report for a user who only has access rights on users through a business unit, selecting them all and exporting to CSV returns "none of selcted objects can be exported to .csv-format".
If i only select 10 and export, it works.
Any ideas?
by (960 points)
What version of Adaxes are you using (including the build number)? We had a similar issue with exporting from reports, but it has already been fixed.
We are using 3.6.10109.0
Can you post here or send us to support[at]adaxes.com a screenshot of the permissions contained in the Security Role and how it is assigned to the user?
Also, can you show us a screenshot og the columns available in the report before the user selects to export?
by (960 points)
I solved this by selecting the domain name instead of "Everywhere" in the "Search In" drop-down list.
Anyway, could you send us the requested information because it looks like an issue that we need to address.
Hello, Similar to exporting the members of a group to a csv file: https://www.adaxes.com/script-repository/export-group-members-to-csv-file-s184.htm I am looking to ... would like to include the memberof csv report in the email as well. Thanks in advance!
asked Feb 7, 2023 by JonnyBGood (20 points)
We would like to be able to export logs from the Adaxes service? Is there a way to do this either through the service or reporting?
asked Oct 31, 2022 by scoutcor (120 points)
So I need to export a list of all user's Line URI's to a CSV file. Running Adaxes 2021 Version 3.14.18804.0 (64 bit) and Teams Powershell 4.1.0 ... a Microsoft 365 account } finally { # Close the connection and release resources Disconnect-MicrosoftTeams }
asked Aug 4, 2022 by TheLexicon (200 points)
HI i'm looking for a way to export the user details (first, last, start date, dept, mgr) once a user gets created so that it sends the details into a "tasking" sheet for our ... online? If not, can i save them locally as a csv or xls with a custom command?
asked Feb 8, 2021 by bboese (20 points)
I tried the script located here: http://www.adaxes.com/script-repository ... s-s346.htm The script works well for most fields (including adm-custom fields), but when ... a value something like "129915720000000000" instead of a date. Any way to resolve this?
asked Feb 15, 2017 by Kikaida (1.1k points)
3,346 questions
7,781 comments
544,980 users
