How can I allow manager of distribution group to edit just email aliases (proxy addresess) of that group? Not the primary SMTP address.
by (910 points)
Email Proxy Addresses is a solid property and there is no possibility to set permissions over part of it. As a workaround, you can use a PowerShell script in a Business Rule triggering Before modifying Exchange properties of a user to set the primary SMTP address back or cancel the whole update if the address was changed. For an example, have a look at the following script from our repository: https://www.adaxes.com/script-repository/make-primary-smtp-addresses-unchangeable-s412.htm. Should you have any difficulties adjusting the script to meet your needs, please, clarify the desired workflow in all the possible details and we will help you.
So there is no possibility to show user just some aliases, so primary SMTP would be hidden? And therefore user cannot modify it? Maybe through some custom form list?
+1
Unfortunately, there is no such possibility. As a workaround, you can configure a synchronization between a custom multi-value attribute (e.g. CustomAttributeTextMultiValue1) and secondary SMTP addresses and allow users to modify the custom attribute. With this approach the users will be able to modify only the duplicates of the secondary SMTP addresses. The solution will work only in Adaxes, its maintenance will be quite difficult and the Email Proxy Addresses property updates performed via third-party tools will be displayed to the users with a delay. If the solution meets your needs, we will provide detailed instructions.
Is is possible through Security Roles, or some other mechanism, to allow managers to be able to edit Active Directory data (through the Web Interface) for only their direct reports and no other users?
asked Mar 23, 2015 by yobhod (150 points)
I am basically setting up the self service portal to only allow a user to reset thier own passwords.
asked Oct 19, 2022 by mightycabal (1.0k points)
asked Jan 19 by aweight (40 points)
3,349 questions
545,066 users
