I'm trying to combine these two scripts to effectively store a user's group memberships in customattributebinary5 and then be able to copy and paste those memberships to a new user in the future. So far I think I have everything except for the pasting of the groups to a new user as I'm having trouble converting the logic from groups to users.
Remove groups from user and store in attribute:
# $groupNamesToSkip = @("MyGroup1", "MyGroup2", "Department*") # TODO: modify me
$groupNamesToSkip = $null
function SkipGroup($patterns, $sAMAccountName)
    foreach ($pattern in $patterns)
        if ($sAMAccountName -like $pattern)
            return $True
    return $False
# Get all groups user is a direct member of
$groupGuids = $Context.TargetObject.GetEx("adm-DirectMemberOfGuid")
# Build a single-dimension array of member GUIDs
$totalBytes = $groupGuids.Count * 16
$result = New-Object 'System.Collections.Generic.List[System.Byte]' $totalBytes
foreach ($GuidBytes in $groupGuids)
    $result.AddRange($GuidBytes)
# Save the GUIDs to the adm-CustomAttributeBinary5 virtual property of target user
$Context.TargetObject.Put("adm-CustomAttributeBinary5", $result.ToArray())
# Get the Primary Group ID
foreach ($groupGuidBytes in $groupGuids)
    # Bind to the group
    $groupGuid = New-Object "System.Guid" (,$groupGuidBytes)
    $groupGuid = $groupGuid.ToString("B")
    $groupPath = "Adaxes://<GUID=$groupGuid>"
    $group = $Context.BindToObject($groupPath)
    # Skip Primary Group
    # Skip special groups
    $sAMAccountName = $group.Get("sAMAccountName")
    if (($groupNamesToSkip -ne $NULL) -and
        (SkipGroup $groupNamesToSkip $sAMAccountName))
    # Remove user from the group
Copy groups from user to initiator:
# Get an array of member GUIDs
    $sourceMemberGuids = $Context.TargetObject.Get("adm-CustomAttributeBinary5")
    $Context.Cancel("Failed to get member GUIDs.")
# Calculate the number of GUIDs
$totalBytes = $sourceMemberGuids.Length
# Make sure that the total number of bytes is a divisible of 16
$remainder = 0
[System.Math]::DivRem($totalBytes, 16, [ref] $remainder)
if ($remainder -ne 0)
    $Context.Cancel("Unexpected data length! Exiting.")
# Save the GUIDs to the adm-CustomAttributeBinary1 virtual property user who invokes the script
$Context.Initiator.UserAdsObject.Put("adm-CustomAttributeBinary1", $sourceMemberGuids)
$Context.Initiator.UserAdsObject.SetInfo()
And finally, need help with pasting, as this doesn't work:
#change this to skip certain groups
    $sourceMemberGuids = $Context.Initiator.UserAdsObject.Get("adm-CustomAttributeBinary1")
$remainder = 0
foreach ($groupGuidBytes in $sourceMemberGuids)
    # Bind to the group
    $groupName = $group.Get("cn")
    # Skip the group if it is the user's Primary Group
    if (($group.Get("primaryGroupToken") -eq $primaryGroupId) -or ($groupNamesToSkip -contains $groupName))
    # Add user to the group
    $Context.LogMessage("Added the user to group '$groupName'", "Information")
by (540 points)
For us to help you with a solution, please, specify what version of Adaxes you are currently using. For information on how to check that, have a look at the following help article: https://www.adaxes.com/help/?HowDoI.ManageService.CheckAdaxesServiceVersion.html.
2019.1 Version 3.11.16825.0
Thank you for clarifying. We suggest that you only use two scripts. The first one will be used to remove all group memberships of a user and save group GUIDs to a custom binary attribute. For example, it can be executed in a Custom Command. The second script will be executed using a Custom Command with an AD object picker parameter. The parameter will be used to specify the user account that has groups the target account should be added to in a custom binary attribute. If this approach meets your needs, we will provide you with the scripts.
Yes, that approach would be sufficent. In our case, the removal of all groups is a scheduled task that runs after a user has been disabled for more than 4 weeks and checks to see that customattributebinary5 is $null. Thanks.
Thank you for the confirmation. We updated the script for removing and preserving groups, find it below. In the script, the $binaryAttributeName variable specifies the LDAP name of the custom binary attribute (e.g. adm-CustomAttributeBinary5) that will be used to store group GUIDs.
$binaryAttributeName = "adm-CustomAttributeBinary5" # TODO: modify me
$groupGuidsBytes = $Context.TargetObject.GetEx("adm-DirectMemberOfGuid")
# Build a single-dimension array of group GUIDs
$totalBytes = $groupGuidsBytes.Count * 16
foreach ($guidBytes in $groupGuidsBytes)
    # Bind to the group
    $guid = [Guid]$guidBytes
    $group = $Context.BindToObject("Adaxes://<GUID=$guid>")
    # Add guid bytes to the array
    $result.AddRange($guidBytes)
if ($result.Count -ne 0)
    # Save the GUIDs to the custom attribute of target user
    $Context.TargetObject.Put($binaryAttributeName, $result.ToArray())
To create the Custom Command for adding users to groups:
  4. On step 2 of the Create Custom Command wizard, select the User object type and click Next. image.png
  5. Click New.
  6. Select AD object picker and click Next.
  1. Specify a parameter name and display name (e.g. userTemplate and User to get groups from). image.png
  2. Click Next.
  3. Click Configure.
  4. In the Display only objects that match the following LDAP filter field, enter the following: (sAMAccountType=805306368) image.png
  5. Click OK and then click Finish.
  6. Click Next.
  7. Click Add an action.
  8. Select Run a program or PowerShell script.
  9. Paste the below script into the Script field. In the script:
    • $binaryAttributeName - Specifies the LDAP name of the custom binary attribute (e.g. adm-CustomAttributeBinary5) that will be used to get group GUIDs from the user selected in the parameter. The LDAP name Should the same as in the $binaryAttributeName variable of the first script.
    • $objectDN - Specifies the distinguished name (DN) of the user selected in the parameter. The DN is obtained using a value reference containing the name of the parameter with the param- prefix (e.g. param-userTemplate).
$objectDN = "%param-userTemplate%" # TODO: modify me
# Get array of group GUIDs
$object = $Context.BindToObjectByDN($objectDN)
    $sourceGroupGuids = $object.Get($binaryAttributeName)
    $Context.Cancel("Failed to get group GUIDs.")
$totalBytes = $sourceGroupGuids.Length
# Make sure that the total number of bytes is divisible by 16
$remainder = 0
    $Context.Cancel("Unexpected data length!")
$groupsToAdd = New-Object "System.Collections.Generic.HashSet[System.Guid]"
for ($i = 0; $i -lt ($totalBytes / 16); $i++)
    $bytes = [System.Guid]::Empty.ToByteArray()
    [System.Array]::Copy($sourceGroupGuids, $i * 16, $bytes, 0, 16)
    $guid = New-Object "System.Guid" (,$bytes)
    $groupsToAdd.Add($guid)
# Get GUIDs of groups the user is member of
$memberOfGuids = $Context.TargetObject.GetEx("adm-DirectMemberOfGuid")
# Adjust the list of groups to add the user to
foreach($memberOfGuidBytes in $memberOfGuids)
    $guid = New-Object "System.Guid" (,$memberOfGuidBytes)
    $groupsToAdd.Remove($guid) # Already a member of the group
# Add to groups
foreach($guid in $groupsToAdd)
        $Context.LogMessage("An error occurred when adding user %fullname% to the group. Error: " + $_.Exception.Message, "Warning")
  2. Click Next and finish creating the Custom Command.
How can I create a script that does these things For internal audit. objective Even removing all groups of a disconnected user, we will still know which groups the ... in the created group (audit)-sAMAccountName-access add the (user)-sAMAccountName in members
asked Jul 2, 2022 by alancardoso (40 points)
With Active Directory Users and Computers, I can add group members by copying a list of usernames and pasting them into the Add Members dialog box. This is very quick and easy. How can I do this with Adaxes? It seems that I can only add one member at a time.
asked Feb 24, 2017 by abarker5 (80 points)
asked Jun 3, 2021 by RayBilyk (230 points)
Hi, Group memberships are kept when using "User Copy" function. Is it possible to do the same thing between two existing users ? (custom commands or else) Thanks for your response, Yoann
asked Oct 4, 2012 by yoann.hamon (180 points)
3,347 questions
7,788 comments
545,045 users
