Hi All,
We are looking at using Adaxes however would like to be able to see the Adaxes logs within McAfee SIEM. Has anyone tried and tested this and could give any insight on the best way to do this?
I understand we can export the logs to CSV and also from SIEM do application monitoring. Does Adaxes have a preferred route to get logs to the SIEM?
Many Thanks!
by (440 points)
Hello Anton,
Unfortunately, we did not perform such tests and have no experience working with McAfee SIEM. We recommend you to check the following approaches with McAfee support team:
  • By default, Adaxes stores log records in a local SQLite database located on the computer where your Adaxes service is installed. The local database is stored in the AdaxesLog.db3 file located in the LogDB subfolder of the folder where the Adaxes service is installed, which is C:\Program Files\Softerra\Adaxes 3\Service by default. If the SIEM can read data from an SQLite database, you can directly access Adaxes logs stored in the database.
  • If the SIEM can read data from an MS SQL database, you can enable logging to an external database and then read the logs from the database.
  • If the SIEM accepts syslog messages, you can enable syslog output to the SIEM server in Adaxes: https://www.adaxes.com/help/?Logging.EnableSyslogOutput.html.
Hello, I'm trying to create a business rule that will update a user account expiry date when that user logs in for the first time. I'm new to Adaxes, so I don't have a ... updated by a user's action, such as "Last Logon". Is it possible to make this work?
asked Mar 6 by sjjb2024 (60 points)
I am trying to view AD authentication logs to see a user account's authentication attempts. Can this be done in Adaxes?
asked Dec 30, 2021 by Tfarmer (160 points)
I'm trying to schedule a report to look in a few specific OUs. Currently "Look in" location only allows for single instance or multiple drop downs. How do I schedule multiple OU locations without creating multiple reports?
asked Jul 2, 2020 by Al (20 points)
I had a script that would copy the values from adm-CustomAttributeTextMultiValue1 and save them into extensionAttribute15 as a comma seperated list. The script somehow got deleted and I can't seem to find the tutorial I used to create it before.
asked Jul 1, 2022 by jordan (110 points)
3,346 questions
7,782 comments
544,984 users
