We are working with an HR package that will send us a CSV file every 4 hours with a list of users that need to be created, modified or deleted from our environment. The CSV file will contain the following fields: companyID,employeeID,givenName,sn,initials,cnx,mail,telephoneNumber,company,department,title,physicalDeliveryOfficeName,HRSystem,EmailAddressneeded,EmployeeStatus,TerminationDate,HireDate,Username
  • The Email_Address_Needed field has the possible values Y or N.
  • If there is a value in the Termination_Date field, that is when the user is to be terminated. (Right now, we have a great Custom Command to do all of that, but it's a manual process to identify the user right now.)
  • If any data is in there, it should be updated/modified (name change, email address change, company change, etc.)
Is there a script that can manage all of that on a scheduled basis?
by (230 points)
Hello Ray,
Have a look at the following script from our repository: https://www.adaxes.com/script-repository/import-new-and-updated-users-from-csv-file-s246.htm. Should you have issues updating the script to meet your needs, please, send us (support[at]adaxes.com) a sample CSV file for import and a detailed description for each of the possible scenarios with live examples.
During the creation of a new user I want to be able to select the job title from a drop-down list which populates different values based on which Department is selected. Is there a way to achieve this? Thanks. Dario.
asked Oct 2, 2020 by winstonsmith (40 points)
We used to run AD Audit and it would provide additional details on what was locking a user's account (workstation name, application, etc...). Is there are way with Adaxes ... on what is locking an account? Or a way to pull historical data on locked accounts?
asked Nov 16, 2020 by pulsifers (20 points)
asked Feb 1 by keneth.figueroa (20 points)
I have a web portal set up specifically for password self service and I would like to include links to our security policies as well as list the password requirements and our support ... Is there a way to include links and/or plain text as a card or something?
asked May 10, 2023 by DA-symplr (80 points)
3,346 questions
7,782 comments
544,987 users
