Is it possible to view Entra Extesions Properties via Adaxes. For example in this article it shows how to add a new property to specify what groups shoudl ... .microsoft.com/en-us/entra/identity/hybrid/cloud-sync/tutorial-directory-extension-group-provisioning
answered 34 minutes ago by Support2 (309k points)
I am looking for a way to adjust how properties are expressed, without creating a custom attribute. For example, the attribute "Lockout-Time" is shown as "enspecified" if ... I was wondering if I could change it without creating a custom attribute. Thank you!
answered 4 days ago by Support2 (309k points)
No edit button is available within Adaxes for these accounts. The service account has 'Mail Recipients' and 'MailRecipientCreation' permissions assigned. What additional configuration or permissions might be needed?
answered Jun 2 by Support2 (309k points)
Hi team, We are running version 2025.1 - 3.17.23904.0 with three servers and one SQL server. Two of the three servers are used for web access behind a load ... issues if we revert to the previous version (internal database/settings and SQL logging database)?
answered Jun 1 by Support2 (309k points)
I have a custom adaxes attribute that I would like to utlitize in Rule Based groups; it does not look like they are available to select, however. Example: want something ... to group. Is this possible to make them visable in the Rule Based queries somehow?
answered May 28 by Support2 (309k points)
I am introducing Adaxes to more of my IT team ... and this includes those who are in DevOps and want to put everything in a Git repo. I'm not an expert on this ... but I've always managed my scripts manually - keeping copies locally in my file system. Thanks.
Hi, from where gets Adaxes the list of values prefilled, especially for the Country attribute? I noticed there is a value of "CS" which is not supported on Active Directory. Thanks.
answered May 27 by Support3 (16.6k points)
We are using Adaxes Directory Object Picker for selecting Distribution Group members. We create external recipients as Exchange Online MailContacts (via New-MailContact). These contacts: are ... Context: We are using cloud-only contacts (no on-prem AD sync).
answered May 27 by Support2 (309k points)
We are getting rid of our internal Active Directory. So far the process has gone very well. All of our 250 users have been transitioned to Entra and all of our applicaitons are ... AD or at the very least you have a cloud only release of Adaxes on the horizon.
answered May 22 by Support2 (309k points)
Hi team, Due to some restructuring in our native AD, we need to update our rule-based groups - specifically the scope of the rules, which need to be changed from ... manage this? I already looked at the SDKs but could not find the best approach. Thanks
answered May 19 by Support2 (309k points)
Hi team, I was trying to check and improve my scripts with AI assistance and attempted to read the relevant SDK pages directly. However, this does not work ... available, or is there an improvement planned to better support fetching information? Thanks.
We're going to be upgrading and Im wondering if there's any caveats we should be aware of in such a major version jump. We have 2 backend servers and 2 frontend servers.
answered May 13 by Support2 (309k points)
When someone is using a Custom Command, can you detect (WIth PowerShell as Action) "who initiated" the Custom Command? I found that you can use e.g.: adm- ... that are available or are only the %Adm-InitiatorFullname%; ...EMail; ...Dn available?
answered May 12 by Support3 (16.6k points)
When creating a scheduled task, you select Object type. e.g.: User but can you add an additional filter, eg. where deparment is a value (HR, IT, ...) or where an ... of the CC add an extra pop-up when e.g more information from the requestor is needed?
answered May 11 by Support2 (309k points)
I found a URL that's being used and I am not sure where it's coming from. I've looked everywhere to see how it's even accessible. The url directs people to a reset ... instead the name of one of the Web Interfaces (I blacked it out in the image below)
answered May 4 by Support2 (309k points)
Adding support for -MemberTimeToLive would be benefitial.
answered Apr 28 by Support2 (309k points)
Would it be best to use the standard Powershell to pull the user's group membership and can that be embedded in a notification email after a user is created? Or is there a variable that will do this that I seem to be missing.
answered Apr 27 by Support2 (309k points)
Hello, Thank you for the clarification. I understand that, as of today, Adaxes does not provide built-in functionality to create Microsoft Entra (Azure AD) guest ... insight you can share regarding roadmap status or long-term direction. Kind regards, Willem
answered Apr 24 by Support2 (309k points)
I find it's a good idea to have backups of a user's group membership when they depart so I'd like to be able to do this.
answered Apr 23 by Support2 (309k points)
This issue may occur when activating a Microsoft 365 account for a user and assigning licenses in the same action. Symptoms The following error is returned: License assignment ... a program or PowerShell script action that adds a 1-minute delay between them.
asked Apr 23 by Adaxes (660 points)
To see more, click for the full list of questions.
