Convert the first character of a property value to uppercase
The script converts the first value character of the specified properties to uppercase. If a value contains multiple parts separated by spaces, the first character of each part will be converted. The script can be used only in a business rule triggering Before creating a user or Before updating a user.
$propertiesToCheck = @("givenName", "sn", "name", "displayName") # TODO: modify me
function FixString ($string)
    return $string.SubString(0, 1).ToUpper() + $string.SubString(1).ToLower()
foreach ($propertyName in $propertiesToCheck)
    # Get property value
    $value = $Context.GetModifiedPropertyValue($propertyName)
    if ([System.String]::IsNullOrEmpty($value))
    # Convert first value character to uppercase
    if ($value -match " ")
        $valueParts = $value.Split(" ") | %%{FixString $_}
        $value = [System.String]::Join(" ", $valueParts)
        $value = FixString $value
    # Update property
    $Context.SetModifiedPropertyValue($propertyName, $value)
Comments 0
