Create groups based on departments of users
The script adds a user to a group with the same name as the user's department. If a group with the necessary name does not exist it will be created.
To use the script, you need to create a business rule triggered automatically once a user is created or updated. For more information on how to automatically run a script once a new user is created, see Run PowerShell Script after Creating a User. Alternatively, you can schedule adding users to groups.
  • $groupOuDn - Specifies the distinguished name (DN) of the Organizational Unit where to search for groups matching departments.
  • $groupType - Specifies what types of groups to create if there isn't a group for a user's department. For a complete list of possible values, see ADS_GROUP_TYPE_ENUM.
$groupName = "Group-%department%" # TODO: modify me
$groupOuDn = "OU=Departments,DC=example,DC=com" # TODO: modify me
[Softerra.Adaxes.Interop.Adsi.ADS_GROUP_TYPE_ENUM]$groupType =
 "ADS_GROUP_TYPE_GLOBAL_GROUP, ADS_GROUP_TYPE_SECURITY_ENABLED" # TODO: modify me
if ([System.String]::IsNullOrEmpty("%department%"))
    return # Department not specified
# Get GUIDs of groups user is a direct member of
    $groupGuidsBytes = $Context.TargetObject.GetEx("adm-DirectMemberOfGuid")
    $groupGuidsBytes = @()
$groupGuids = New-Object "System.Collections.Generic.HashSet[System.Guid]"
$groupGuidsBytes | %%{[void]$groupGuids.Add([Guid]$_)}
# Search group for department
$searcher = $Context.BindToObject("Adaxes://$domainName/RootDSE")
$searcher.SearchFilter = "(&(objectClass=group)(name=$groupName))"
$searcher.SetPropertiesToLoad(@("ObjectGuid"))
    if ($searchResults.Length -ge 1)
            $guid = [Guid]$searchResult.Properties["ObjectGuid"].Value
            if ($groupGuids.Contains($guid))
                continue # The user is already a member of an appropriate group
            # Group found, add user
            $departmentGroup = $Context.BindToObject($searchResult.AdsPath)
            $departmentGroup.Add($Context.TargetObject.AdsPath)
        # Group not found, create one
        $targetContainer = $Context.BindToObjectByDN($groupOuDn)
        $departmentGroup = $targetContainer.Create("group","CN=$groupName")
        $departmentGroup.Put("groupType", [Int32]$groupType)
        $departmentGroup.Put("sAMAccountName", $groupName)
        $departmentGroup.SetInfo()
        # Add user
    $Context.LogMessage("An error occurred when adding the user to group '$groupName'. Error: " + $_.Exception.Message, "Warning")
Comments 0
