Enable or disable specific Web interface
The scripts enable or disable the specified Web interface.
Script 1: Adaxes scheduled task
To execute the script, create a scheduled task configured for the Domain-DNS object type and add a single managed domain to the Activity Scope of the task.
  • $webUIConfigurationName - Specifies the name of the Web interface to enable or disable.
  • $enabled - Specifies whether the Web interface will be enabled or disabled.
$webUIConfigurationName = "HelpDesk" # TODO: modify me
$enabled = $false # TODO: modify me
# Get Web interface configuration
$webuiConfigPath = $Context.GetWellKnownContainerPath("WebUIConfigurationContainer")
$webuiConfigContainer = $Context.BindToObject($webuiConfigPath)
$webUIConfiguration = $webuiConfigContainer.GetConfiguration($webUIConfigurationName)
# Update configuration
$webUIConfiguration.Enabled = $enabled
$webUIConfiguration.SetInfo()
Script 2: external execution
Execute the script in Windows PowerShell on the computer where Adaxes service is installed. When prompted, specify the credentials of the Adaxes service account (specified during Adaxes installation).
$webuiConfigPath = $admService.Backend.GetConfigurationContainerPath(
$credential = Get-Credential
$webuiConfigContainer = $admService.OpenObject($webuiConfigPath, $credential.UserName, $credential.GetNetworkCredential().Password, 0)
Comments 0
