Top 10 Approvers
The script creates and emails an HTML-formatted report on top 10 users who approved more operations than the others.
Note: The script uses the $Context variable available on the server side only. This means that the script can be executed only by business rules, custom commands, and scheduled tasks. For example, to schedule the report, you can create a scheduled task configured for the Domain object type. To add the script to a scheduled task, use the Run a program or PowerShell script action.
  • $to - Specifies email addresses of the recipient(s) of the report.
  • $subject - Specifies the email message subject.
  • $reportHeader - Specifies the email message header.
  • $reportFooter - Specifies the email message footer.
# E-mail message settings
$subject = "Top 10 Approvers" # TODO: modify me
$reportHeader = "<h2><b>Top 10 Approvers</b></h2>" # TODO: modify me
function GetDisplayName($path)
    return $Context.GetDisplayNameFromAdsPath($path)
# FInd all approved requests
$containerPath = $Context.GetWellKnownContainerPath("ApprovalRequests")
$searcher = $Context.BindToObject($containerPath)
$searcher.SearchFilter = "(&(objectClass=adm-ApprovalRequest)(adm-ApprovalState=1))"
$searcher.SetPropertiesToLoad(@("adm-ProcessedByGuid"))
    $requests = $searchResult.FetchAll()
    $approverInfo = @{}
    foreach ($requestId in $requests)
        $approverGuid = [Guid]$requestId.Properties["adm-ProcessedByGuid"].Value
        if ($approverInfo.ContainsKey($approverGuid))
            $approverInfo[$approverGuid] += 1
            $approverInfo.Add($approverGuid, 1) | Out-Null
    $searchResult.Dispose()
# Get top 10 approvers
$result = $approverInfo.GetEnumerator() | Sort value -Descending | Select -First 10
    $Context.LogMessage("Default web interface address not set for Adaxes service. For details, see http://www.adaxes.com/help/?HowDoI.ManageService.RegisterWebInterface.html", "Warning")
# Build report
$reportHeader += "<ol>"
foreach ($entry in $result)
    $approverGuid = $entry.Key
    $path = "Adaxes://<GUID=$approverGuid>"
    # Add approver info to the report
    $approver = $Context.BindToObject($path)
    $approverDisplayName = GetDisplayName $approver.AdsPath
    $processedRequests = $entry.Value
    $reportHeader += "<li><a href='$webInterfaceAddress`#/Browse/$approverGuid'>$approverDisplayName</a>; <br/>Processed requests: $processedRequests</li>"
$reportHeader += "</ol>"
# Send mail
$report = $reportHeader + $reportFooter
$Context.SendMail($to, $subject, $NULL, $report)
Comments 0
