Users whose property values do not match property pattern
The script generates a report that will include users whose property values do not match the ones allowed by effective property patterns. Also, the report will include users with empty properties that are mandatory according to effective property patterns. To execute the script, create a report with a scope that will include users that should be checked by the script.
function IsUserPropertiesValid($propertyPatternDN, $user)
    # Bind to the Property Pattern
    $propertyPattern = $Context.BindToObjectByDN($propertyPatternDN)
    # Get all properties from the Property Pattern to load
    $propertiesToLoad = @()
    foreach($item in $propertyPattern.Items)
        $propertiesToLoad += $item.PropertyName
    $user.GetInfoEx($propertiesToLoad, 0)
    $userPropertyList = $user.PropertyList
        # Get property entry
            $propertyEntry = $userPropertyList.Item($item.PropertyName)
            if ($item.IsPropertyRequired)
                return $False
        if ($item.IsPropertyRequired -and ($propertyEntry.Values.Length -le 0))
            return $False
        $propertyEntry.ControlCode = "ADS_PROPERTY_UPDATE"
        # Get constraints
        foreach($constraint in $constraints)
            $errorMsg = $NULL
            if ($constraint.Check($propertyEntry, $user, [ref]$errorMsg))
            return $False
    return $True
    $Context.DirectorySearcher.AppendFilter("(sAMAccountType=805306368)")
        $user = $Context.BindToObjectBySearchResult($searchIterator.Current)
        # Get Property Patterns effective for the user
            $propertyPatternDNs = $user.GetEx("adm-EffectivePropertyPatterns")
        $user.GetInfo()
        foreach($propertyPatternDN in $propertyPatternDNs)
            if (IsUserPropertiesValid $propertyPatternDN $user)
            $Context.Items.Add($user)
            break
Comments 0
