Unable to select the option "Hide from exchange addres list" from shared mailbox that is being managed via Adaxes
Getting this error The operation on mailbox "6e481282-3419-43a0-8fed-6950c970fec5" failed because it's out of the current user's write scope. The action 'Set-Mailbox', 'HiddenFromAddressListsEnabled', can't be performed on the object '6e481282-3419-43a0-8fed-6950c970fec5' because the object is being synchronized from your on-premises organization. This action should be performed on the object in your on-premises organization.
Unfortunately, it is a known issue caused by the changes made by Microsoft. To resolve the issue, you need to upgrade. Download and What’s New links are below. For information on how to check the version of Adaxes you are using, see https://www.adaxes.com/help/CheckServiceVersion.
Upgrade instructions
Adaxes 2023.2
Download
What’s New
Adaxes 2023
Download
What’s New
Adaxes 2021.1
Download
What’s New
I am trying to have a scheduled job that will hide groups that are empty and I can not seem to figure out how to do it.
asked Aug 20, 2021 by hgletifer (1.3k points)
Hi Team! I'm currently looking for a solution to create an exchange mailbox on-premise, sync it to Office 365 and assign the license in one business rule. I didn't ... solution from our side? Please let me know how to configure this. Best Regards Marco Jandl
asked Apr 6, 2022 by marco_jandl (60 points)
I am trying to get a better understanding of how all this works, so forgive me if some of these questions don't make sense. We are trying to remove our final Exchange On ... to the cloud, then I would need to keep our last on-prem exchange server running?
asked Jan 9 by emeisner (160 points)
We have a Deprovision Rule in where we want to set "hide from address lists" in exchange, if it is not already set. but this does not work? what can i do, to first check if this is already set?
asked Oct 21, 2020 by m_st (200 points)
3,733 questions
8,630 comments
550,211 users
