Script repository
Request users to approve adding their managed objects and subordinates to group
The script can be used to request approval of a manager or owner of an AD object before adding it to a group. To run the script, create a business rule triggering Before adding a member to a group.
# Bind to new member
    # Try getting the manager's DN
    $approverDN = $member.Get("manager")
        # Try getting the owner's DN
        $approverDN = $member.Get("managedBy")
        # The new member has neither a manager, nor an owner
        $Context.Cancel("Cannot add the object to the group because the object you are trying to add has neither a manager, nor an owner") # TODO: modify me
# Submit for approval
$Context.SubmitForApproval(@($approverDN), $False, $False, $False, $False)
Comments 0
