Hello -
Currently we are on v 2013.1 version 3.59329. I'd like to upgrade to the latest.
Would the below path correct and is there anything I need to know prior to upgrading?
2013.1 -> 2014.1 -> 2015 ?
Thank You
by (1.7k points)
No, you can go straight from Adaxes 2013.1 to Adaxes 2015. 2013.1 -> 2015
Have a look at Upgrade Instructions.
thanks!
I am having the same issue as the previous commenter. When I export the manager value it is including the path with the name. For the automation I am wanting to ... manager name without any additional information. Could you please help me with this? Thanks.
asked Feb 13, 2023 by lwood (20 points)
In the Reports section, there is an option to view "All Users" and then export the view. There is also an option to include additional columns. If I include "Manager", ... along with the complete AD path gets exported. Is it possible to export only the name?
asked Jan 14, 2014 by sdavidson (730 points)
I tried following the instructions in this tutorial: http://adaxes.com/tutorials_AutomatingD ... wUsers.htm When I get to the section "In the dialog that opens, select the Remote ... , even if I select the "Show all properties (Alt+A)" Thanks in advance.
asked Mar 15, 2013 by Kikaida (1.1k points)
Send Mail with integrated mail sending function isn´t working anymore with SSL after Upgrade to 2023.2. The error code is "Send Mail with integrated mail sending function isn´t ... is working if SSL is not enabled. Does someone else have the same problem?
asked Sep 11, 2023 by robin.christmann (160 points)
3,356 questions
7,799 comments
545,167 users
