Good afternoon,
I'm looking to generate a script to allow automation of updating job titles using a spreadsheet.
To do this we would use a spreadsheet generated by another team called "UserExportSpreadsheet" (See attached for sanitized copy). Example of Spreadsheet And basically if a user's job title in the spreadsheet is different from AD (using columns B and O in the spreadsheet for reference against EmployeeID and Job Title in AD).
We would run this command once a month using a scheduled task. But i'm looking for assistance with the proper scripting and in calling the file.
Please let me know if you require any additional information Regards
by (680 points)
by (273k points)
You can use Script 2: Only update existing users from the following article in our repository: https://www.adaxes.com/script-repository/import-new-and-updated-users-from-csv-file-s246.htm. If you need to modify the script but face issues to do so, please, provide all the possible details regarding the desired behavior with live examples and we will help you.
Hi Currently we have an Adaxes system set up for our Service Desk staff to log into and manage users / groups etc this is currently assigned by assigning the Service ... there be any limiting factors such as licencing requirements for this? Thanks in advance.
asked Dec 15, 2020 by R_C (70 points)
I am searching for a good workflow for changing the manager field of users when there is a change in management. I was thinking of doing it based off job title. So I was ... of job titles so that would be ideal. Thanks for the help and the awesome product.
asked Oct 1, 2022 by Dynamic6553 (20 points)
Is there a report that I can run that shows everyone with a specific job title
asked Apr 20, 2023 by sra98a (120 points)
If I wanted to exclude a list of job titles from this report how would I update the script?
asked Nov 18, 2019 by hgletifer (1.3k points)
We have a property pattern for a user's job title that lists all the aviable titles. I need to be able to add a new constraint to this within a custom command and from Powershell on a differant computer. Would you be able to help?
asked Sep 23, 2020 by hgletifer (1.3k points)
545,372 users
