I am looking for the option to be able to utilize this with a Multi-Domain/Multi-Tenant Environment. Provide specific managers on a specific domain under a client access, etc.
In Adaxes, you can manage multiple AD domains in a single place even if the domains do not have trust relationships. Also, you can granularly grant permissions, so that users from one domain do not see objects in other domains, etc. For details, have a look at the following articles: https://www.adaxes.com/active-directory_management.htm https://www.adaxes.com/active-directory_delegation.htm
Can you clarify the answer as it's a bit confusing? Will there be new major release available this month?
asked Nov 17, 2022 by ColinB (180 points)
Our Adaxes Microsoft 365 Tenant was created before we copmpleted the "app registration" in Azure. Which means that in the instructions for "Register Adaxes as an app in ... M365 tenant, would that affect any of our custom commands that we have created?
asked Feb 17, 2022 by Tfarmer (160 points)
Hello! I have an environment with three separate forests. One has Exchange 2010, the second has Exchange 2013 and the third has Exchange 2016. These environments don't have a ... an internal CA. Somebody please help me because I feel like I"m going crazy.
asked Jan 11, 2018 by loliver (120 points)
Hi, We have a multi-domain forest with a root domain and three child domains. Adaxes is currently installed in one of these child domain and i would like to deploy a new Adaxes ... luck. I don't know where to check so if you have a clue. Thanks in advance
asked Dec 11, 2011 by sroux (800 points)
Is it possible to add multiple members to a group in a singe call to the REST API? The example code only shows a single member. What would the data structure look like in that case?
asked Dec 13, 2021 by swengr59 (60 points)
7,802 comments
545,175 users
