I've got the script working as is and would like to add a column to display the number of days left before the password expires. I attempted to use adm-AccountExpiresDaysLeft value reference but it threw an error, probably because I don't know how to convert it to a displayable format.
by (870 points)
For us to help you with a solution, please, specify the version of Adaxes you are currently using. For information on how to check that, have a look at the following help article: https://www.adaxes.com/help/CheckServiceVersion.
We're using version 2019.2.
Thanks...
Thank you for specifying. In the version you have, you can use the built-in Password expiration report. By default, the report is located in container Reports\All Reports\Users\Passwords. If this is not exactly what you need or you have issues adjusting the report to meet your needs, please, provide all the possible details regarding the desired report with live examples.
We have a single AD domain that also matches our primary email domain (e.g. @primarydomain.com), but we also have multiple company specific email domains (e.g. @companydomain. ... like to also link the companydomain.com to the user's company value set in AD.
asked Apr 29, 2020 by JacquesKruger (20 points)
Changing the "Forgot your password?" text.
asked Mar 10, 2020 by msylvester (60 points)
Hi, I recently upgraded Adaxes from 2021.1 to 2023.2, and after the upgrade, an LDAP filter for retrieving the groups a user is owner of, stopped working. The reason ... attribute instead, like this: It works, but sadly it is quite slow. Best regards Martin
asked Aug 21, 2023 by Martin (100 points)
I have a web view set up where the user is locked down to only seeing thier approvals. When they get a email notification, and click on the approve or deny link, ... that would grant this access but I am wondering if there is something I am missing.
asked Apr 7, 2023 by mightycabal (1.0k points)
Hi, I want to change the default UPN suffix for user creation. We only have a single UPN suffix we use at our organization however when we create a user using the web ... We only ever want to use the @mycompany.com so a list of options isn't requried.
asked Jun 29, 2022 by PeterG (40 points)
7,805 comments
545,195 users
