Hello
when I export a report like "Active computers" to XLSX, column Last-Logon-Timestamp will only be recogniced in Excel as text format. Is this a normal behaviour or perhaps a language problem between Windows and Office? We have English Windows installation with German Input language, Format and Location.
regards Helmut
by (510 points)
Yes, this is a normal behavior. All cells in exported reports have the General format.
I tried the script located here: http://www.adaxes.com/script-repository ... s-s346.htm The script works well for most fields (including adm-custom fields), but when ... a value something like "129915720000000000" instead of a date. Any way to resolve this?
asked Feb 15, 2017 by Kikaida (1.1k points)
I am trying to create a report-specific column (DateTime - Regular Date) where I can extract the datetime from the description field of the user object using a regular ... () $line = $object.Get("description") $dateTime = ?? $Context.Value = $dateTime
asked Feb 27 by emeisner (60 points)
+2 votes
I am attempting to build out a report that shows all user accounts were approved by two different persons before being created. I have the workflow running correctly, ... this data stored in a specific location thats accessible by the reporting engine? Thanks!
asked Dec 16, 2019 by hendersonw (210 points)
How can we export a report with a filter applied? When running a report, and applying a filter and clicking export to say Excel, all results from the report ... instead prints only the filtered results, we would like to export filtered results. Thanks!
asked Aug 18, 2023 by curtisa (210 points)
I have a report that I am exporting to a directory but the output has two issues which are not usable for an import at another system after an automated FTP. ... the automated process cannot have any extraneous columns and the Name column would be one.
asked Mar 16, 2023 by techg (320 points)
7,805 comments
545,184 users
