Since today were receiving the below error when attempting to add additional email addresses to users via Adaxes.
An Azure Active Directory call was made to keep object in sync between Azure Active Directory and Exchange Online. However, it failed. Detailed error message:
Unable to update the specified properties for on-premises mastered Directory Sync objects or objects currently undergoing migration. RequestId
I read through this post but we are on version: 3.13.18106.0 https://www.adaxes.com/questions/9585/receiving-an-error-when-trying-to-add-an-smtp-address
How do we fix to get the ability to add email addresses via Adaxes again?
by (320 points)
Experiencing same issue here.
by (273k points)
Unfortunately, this is a known issue that occurred due to the recent changes performed by Microsoft. We have just released an update for Adaxes 2020.1 that you are using with a fix for the issue. You can download it here.
Upgrade instructions
What's New
I'm trying to modify mailbox settings to add additional email addresses to a user after creation. This is a hybrid on-prem and Exchange Online with E5 licenses. Everything works up ... to a different OU during the process so I know the user exists. Any ideas?
asked Mar 6, 2023 by Michael Long (70 points)
Good Morning, On our help desk's actions they have two options, "Add to Group" and "Modify User". When they attempt to add a user to a group with "Add to group", ... help desk security role full access to group objects, but still no luck. Any ideas? Thanks.
asked Feb 18, 2016 by jhair (520 points)
Hi, I need to create a number of mail user accounts via Adaxes and a lot of these accounts have & in the displayname/email address etc (I know, I know ... failed so I can troubleshoot it better. I have tried $context.logmessage($_.Exception.Message) Thanks
asked May 9 by typod (50 points)
We have a single AD domain that also matches our primary email domain (e.g. @primarydomain.com), but we also have multiple company specific email domains (e.g. @companydomain. ... like to also link the companydomain.com to the user's company value set in AD.
asked Apr 29, 2020 by JacquesKruger (20 points)
We have been able to add email addresses using the script in E-Mail Addresses Is there a way to reverse the process and specify the smtp address you want to remove using a similar subset of code.
asked Dec 14, 2022 by martin.mcclorey (40 points)
545,389 users
