I'm trying to make a BU to capture user accounts that haven't logged in to AD in 60 days. I have a BU with the following Query, but it isn't working
(&(sAMAccountType=805306368)(Last-Logon-TimeStamp<="%datetime,-2M%"))
Any thoughts? I know I can use a script, but I just thought a BU made sense. This way I can automatically disable those accounts with a scheduled task.
PS. I know I can do this with a script. I just thought it would be easy to do with a BU
Thx!
--Joel
by (470 points)
Hello Joel,
No, you can't build a Business Unit that would include disabled user accounts because currently it is impossible to build a LDAP filter that includes the current date.
By the way, there is a built-in Scheduled Task for handling inactive users called Inactive User Deleter. For more information, have a look at the following tutorial: Automatically Deprovision Inactive AD Users.
Hi there, I've a business unit containing all shared mailboxes. In The Admin Console the filter is okay and the affected objects show the accounts: But when ... provide a list of all shared mailboxes (which are disabled aswell). Kind regards Constantin
asked May 28, 2021 by Constey (190 points)
Is it possible to have a business unit that contains the expired accounts?
asked Sep 14, 2017 by adaxes_user (420 points)
Hello, Is there a built in method for checking user accounts that have expired in Azure?
asked Jul 31, 2023 by Homelander90 (330 points)
3,372 questions
545,357 users
