My company is having 3 types of employess agents, employee and contractors. while user creation in adaxes i want to keep Manager, department and job title mandatory and I can keep in property patten. But employee and contractor will have manager, department and there will be no manager and jobtitle, and department for agent. While creating a user if it is agent I can't create the user because i kept mandatory for manager and department.
by (40 points)
by (277k points)
Property patterns only work upon user creation if assigned over domains, OUs and containers. If you have different types of users created in different OUs, you need to create a separate property pattern for each OU. The following tutorial (section Different Patterns for Different Users) should be helpful: https://www.adaxes.com/tutorials_SimplifyingDataEntry_MakePropertyRequiredAndSpecifyFormat.htm.
If the users can all reside in the same location, you can keep the required option enabled for the properties that are mandatory for all types of users. Alongside, use a business rule triggering Before creating a user that will cancel the operation if an agent is created without a manager. For example, if the user type is stored in the Employee Type property, the rule will look like the following: image.png
Adaxes really needs this i.e. "Here's this list of 20 users can you add them to the Marketing group" - right now you have to do them one at a time which is a real kludge. I ... there's any timescale please? We're on 2013.2 if I'm just not seeing it. Thanks :)
asked Jan 30, 2014 by hutchingsp (240 points)
Hello, we offer our team leads to manage their teams: - the manager select "My Team" - then all member of the team are listed - the manager selects a member of the team and ... by") :o How can I set such a filter which restricts the groups? Many thanks, Horst
asked Mar 23, 2018 by HorstR (460 points)
I tried searching and looking through the script repo but I coun't find what I was looking for. Is there a script I can use with "If PowerShell scripts returns true" ... want to run a scheduled job only on mailboxes that are NOT Shared Mailboxes. Thank you,
asked Sep 26, 2022 by hgletifer (1.3k points)
User received email from Lumifi and wanted to verify if legit or if this is not from Adaxes?
asked Nov 30, 2022 by Jeff.Briand (60 points)
3,403 questions
7,894 comments
545,713 users
