When trying to add multiple groups to a user after searching in the group list we are seeing that selecting one group adds that one then the complete list of groups shows again.
How do select all groups from the search results without the list refreshing not just the first group selected?
by (320 points)
Could you, please, provide all the steps you take to add a user to groups with screenshots? You can post the screenshots here or send them to us (support@adaxes.com).
Thank you for the details you sent. According to the screenshots, the situation is as follows:
  1. You are using the Add to group action.
  2. On the group selection step, you enter a filter for search and matching groups are displayed.
  3. When you select a group, the filter is gone and you need to enter it again to select another group.
This behavior is by design and unfortunately, there is currently no work around for it. However, thank you for the suggestion. We forwarded it to the corresponding department for consideration.
Hi It would be a great feature add to have a checkbox next to the group name to ensure the filter remains.
Is there a possibility to add a ctrl+click function?
Hello Jimmy,
Thank you for the suggestion. We forwarded it to the corresponding department for consideration.
Hi - How can I remove the option of allowing "Copy User Groups" during the copy user process in the interface. I'd like to have it hidden but still active so to not allow our HR team to accidently unclick it during the process.
asked Oct 15, 2019 by 6FigureMission (140 points)
asked Jan 16 by dominik.stawny (160 points)
We're finding more and more that we would like the ability to configure a home page action that can target objects from multiple OUs. In other words, under "Object Selection ... LDAP filter but was hoping you all might know a way around this. Thanks in advance
asked Oct 16, 2012 by VTPatsFan (610 points)
Good Afternoon, I have been looking through the forums and I might have missed it, but here's what I'm looking to do. I have 3 groups in my AD environment with Top, Middle ... result Is there a way to show it on the Web interface or create a report like this?
asked Apr 27, 2022 by Sandberg94 (340 points)
Adaxes Support, Is there a way to disable the Nested Group function of Active Directory in Adaxes. We are using some nested groups in rare cases but our corporate ... or blocking users that manage groups to only added members and not nest groups. Rodney
asked Aug 29, 2013 by rjthompson (80 points)
3,350 questions
545,070 users
