Is there any way to make Password Self Service Policies OR Operation?
Let say, user can enroll to both Q&A and OTP App Google Authenication. However, during the password reset, user can choose either to use Q&A or OTP App.
by (170 points)
Unfortunately, there is no such possibility. Once a user is enrolled for Password Self-Service, to reset their password they will have to verify through all the options enabled in the self-service policy.
well noted.
hopefully we can have this option in the future.
Is there a way to allow users to either answer the self-service reset questions OR get an SMS/Email verification? I can see how to set a policy for either one, but is there any way to enable an end user to choose which to use?
asked Apr 4, 2016 by johnsonua (390 points)
We are looking to implement Self-Password reset for users through Adaxes and need the following information: Is there any additional licensing costs to use the Adaxes Self- ... the earliest version of Adaxes that the client is available? Thank you in advance.
asked Jan 7, 2021 by lgibbens (320 points)
We have multiple secondary domains that are being managed by Adaxes. Everything seems to be working except self service portal login. We tested with our other secondary domains and those ... other than sign failed. What else can I look at to figure this out?
asked Aug 21, 2020 by mark.it.admin (2.3k points)
is it possible to allow a user to enroll for both options, or even only one option out of the two available? I would like to give my users the choice to use either. Some users may not want an authenticator, but other's might do.
asked Nov 6, 2019 by mashworth (80 points)
3,351 questions
545,081 users
