Here is what i have been trying with
Set-ADUser -Identity $user -Clear "extensionAttribute5" Set-ADUser -Identity $user -Add @{extensionAttribute5 = "NoLicenseNeeded"}
There is no need to use scripts to achieve the desired behavior. It can be done using the Update the user action in your deprovisioning workflow. For example, if you use a custom command to deprovision users, it will look like the following: image.png For your information, the clear action is not required if you need to only set Extension Attribute 5 to NoLicenseNeeded.
Hello! Is there a way to clear the AD attribute "thumbnailPhoto" with a checkbox property? I wanted to implement a checkbox in the mask "Modify user" and if the box is checked, clear the attribute. How do I implement this? Much appreciated, Marco
asked Apr 21, 2022 by marco_jandl (60 points)
asked Mar 21 by EdgarsABG (50 points)
asked Apr 22, 2020 by RayBilyk (230 points)
asked Oct 24, 2022 by mightycabal (1.0k points)
7,806 comments
545,202 users
