when we have 1000 license and current active user is 1000, what will happen with below situation:
  1. We created new users directly from Active Directory. Will this user recognize by Adaxes? Will Adaxes still functioning?
  2. We create user though Adaxes. Will it possible or Adaxes will return some error?
by (170 points)
Yes.
If the new user is enabled and not expired, it will violate the license. You will have 30 days to remedy the issue before Adaxes stops functioning. It can be done by extending your license or adding specific users to the unmanaged list. For details on how to manage the list, have a look at the following help article: https://www.adaxes.com/help/AddUsersToUnmanagedList.
There will be no issues creating the user. However, counting the period for license violation will start.
So, if we violate the licence, Adaxes will still works for 30days and after that will stop functioning?
Yes, that is correct.
well noted. thanks.
We are very favorably impressed with the software and are beginning to explore pricing. One concern we have is about licensing for the correct number of accounts. WIth MS products, ... information, so feel free to repsond to me directly on this. Thank you, d.
asked Jun 28, 2013 by dbarry (40 points)
is there a way to get other "add on " licenses assigned in Adaxes for Microsft cloud that arenot under the Business or E3 licenses?
asked Jun 3, 2021 by Derek.Axe (480 points)
We are looking to implement Self-Password reset for users through Adaxes and need the following information: Is there any additional licensing costs to use the Adaxes Self- ... the earliest version of Adaxes that the client is available? Thank you in advance.
asked Jan 7, 2021 by lgibbens (320 points)
Hello Q1: When a user (on the WebUI) cancels a pending request, he recieves a mail notification, saying that he (just) cancelled a request ?!? Hmmmm.... How can we "route ... " 2 - "Maximum allowed number of enabled and not expired accounts" ------ - Thanks
asked Mar 30, 2016 by Boxx.dk (2.6k points)
Hello We have 2 Adaxes service servers which should be configured as a high availability pair. Our main server is licensed correctly but we can't get into the Adaxes console on ... any help as we need to have HA tested before rolling out to users. Thank you
asked Nov 10, 2014 by CBurn (700 points)
3,362 questions
7,812 comments
545,231 users
