Since last update (to correct web.config bug), it seems that %fullname% variable returns fullname of the initiator instead of fullname of created object.
by (800 points)
We can't reproduce the issue in our environment.
Could you please provide more details. Where do you use the %fullname% value reference? Could you post a screenshot here?
We have a custom date attribute that has stopped working correctly, it is set for indicating a new user's start date in an account creation form. This is then used to generate a ... the date is the wrong way round, the server is set as a UK date/time format.
asked Mar 9, 2023 by mashworth (80 points)
Hi Adax users are unable to load any exchange information when using the Adaxes front end. When trying to load exchange information or any exchange related task they get the ... tenants is set up and says last AD Connect time was 30 minutes ago. Thanks
asked Feb 16, 2021 by R_C (70 points)
Hi All, I have an OU ADSynced to Office 365 When I create Shared Mailboxes I basically create the user account sync it to 365 Assign it a license and and set ... only process the below actions if the previous one returned an Operation status of "Completed"
asked Oct 26, 2020 by casey101 (20 points)
Hi all, Just wondering when Adaxes actually determines the current unmanaged/managed user counts - is it random, scheduled, or a manual thing? Also, does it randomly re-determine ... the script ran successfully every night, so I am not sure here. Cheers all.
asked Sep 22, 2020 by TheLexicon (200 points)
3,371 questions
545,353 users
