We are trying to do a report on weak passwords, but i dont think adaxes is able to?
by (40 points)
Unfortunately, there is no possibility to generate a report on weak passwords in Adaxes.
For example, if the scope is a specified OU, running the report will list management history for every object in the OU even if it has had no management operations ... so objects that have not had any recent modifications are excluded from the report results?
asked Aug 13, 2021 by ryan741 (120 points)
asked Apr 14, 2023 by mightycabal (1.0k points)
7,805 comments
545,194 users
