When I create a user from adaxes I also want it to be added to MS Teams groups.
At this moment i create the account in adaxes after that i need to add this user in all groups that we have in MS Teams so i what to automate this when i create a new usuer.
by (40 points)
by (16.1k points)
Yes, it is possible using a business rule, scheduled task, and a PowerShell script. The business rule triggering After creating a user will enable a Microsoft 365 account for the user, assign a license and mark the user by setting a custom Boolean attribute to true. The mark is required as the user creation in Microsoft Teams requires some time and the user will be added to the teams in a scheduled task. The task will process only the users that were marked in the business rule. A PowerShell script executed in the task will connect to Microsoft Teams, check if the user account exists, and if it does, the script will add the user to all teams. Then the script will clear the mark set by the business rule. To create the rule and the task:
i. Creating the business rule
  3. In the context menu, navigate to New and then click Business Rule. image.png
  4. On step 2 of the Create Business Rule wizard, select the User object type.
  6. Click Next.
  7. Click Add an action.
  8. Select Activate or modify Microsoft 365 account.
  9. In the Actions Parameters section, select the Activate option.
  11. Click OK.
  13. Select Update the user.
  15. In the Property to modify field, select custom Boolean attribute (e.g. CustomAttributeBoolean1). The attribute will be used to mark the user for further processing in a scheduled task.
  17. Click OK twice.
  18. Click Next and finish creating the business rule.
ii. Creating the scheduled task
  3. In the context menu, navigate to New and then click Scheduled Task. image.png
  4. On step 3 of the Create Scheduled Task wizard, select the User object type.
  5. Click Next.
  6. Click Add an action.
  8. Paste the below script into the Script field. In the script, the $markAttributeName variable specifies the LDAP name of the custom Boolean attribute used to mark the created users for further processing in the scheduled task. Must be the same as the one you specified on step 16 in section i.
$markAttributeName = "adm-CustomAttributeBoolean1" # TODO: modify me
# Get saved credentials
$username = $Context.RunAs.UserName
$password = $Context.RunAs.Password | ConvertTo-SecureString -AsPlainText -Force
$credential = New-Object System.Management.Automation.PsCredential($username, $password)
    # Get the object ID in Microsoft 365
    $objectId = ([Guid]$Context.TargetObject.Get("adm-O365ObjectId")).ToString()
    return # The user doesn't have a Microsoft 365 account
    # Get the user in Microsoft Teams
    Connect-MicrosoftTeams -Credential $credential
    $user = Get-CsOnlineUser -Filter "Identity -eq '$objectId'"
    if ($NULL -eq $user)
        $Context.LogMessage("The user does not have a Microsoft Teams account", "Information")
        return # User does not exist in Microsoft Teams
    # Get all teams in Microsoft Teams
    $teams = Get-Team
    foreach ($team in $teams)
        # Add the user to the team
        Add-TeamUser -GroupId $team.GroupId -User $user.Identity
    # Clear the mark attribute
    $Context.TargetObject.Put($markAttributeName, $NULL)
    # Close the connection and release resources
    Disconnect-MicrosoftTeams
  2. In the Run As section, select the This account option.
  4. Specify username and password of the Microsoft 365 account that has permission to add users to teams in Microsoft Teams. image.png
  5. Click OK twice.
  7. Select If \ \ \.
  8. Select If CustomAttributeBollean1 equals True. The specified attribute must be the same as the one whose name you specified in the $markAttributeName variable on step 8. image.png
  9. Click OK.
  10. Click Next and finish creating the scheduled task.
I am trying to connect to teams via powershell in adaxes to run the following commands. Set-CsUser -Identity -EnterpriseVoiceEnabled $true -HostedVoiceMail $true Grant- ... )" I am not able to run the following though, Connect-MicrosoftTeams
asked Apr 22, 2021 by TJ_Umredkar (140 points)
asked Jun 30, 2021 by RayBilyk (260 points)
When setting up a rule based group, GMSA objects are not visible. Is there a setting or view I need to add to make these availabe to rule based groups, or is it simply not an option?
asked Sep 16, 2024 by ajmilic (130 points)
This would seem like an easy setting since right now, it's causing so much logs because on the main screen, I have a few reports that are custom made and everytime a user ... . Below is a screenshot example of hoe it constantly can fill up the log. Thank You!
asked Jul 31, 2023 by Edogstraus00 (590 points)
