When I add the property MsExchActiveSyncEnabled it seems to always be blank.
How to fix?
by (90 points)
Unfortunately, there is no possibility to view the property value anywhere. It is an internal Adaxes property that is only used on the backend to work with Exchange properties.
Would it be possible to create a custom virtual Adaxes Property, and then setup a Business Rule to copy the internal MsExchActiveSyncEnabled value to it? And then display the custom virtual Adaxes property on the portal?
Unfortunately, it is not possible. The number of Adaxes custom attributes is fixed and cannot be changed.
It is generally not possible to pull the value of the MsExchActiveSyncEnabled property. As we mentioned it is only used on the Adaxes backend. As an option, it is possible to have a scheduled task set a custom Boolean attribute of a user to true in case the user has the Exchange ActiveSync feature enabled. Also, there will be a business rule triggering After modifying Exchange properties of a user that will update the attribute according to the feature state. Will the approach meet your needs? If not, please, describe the desired behaviour in all the possible details with live examples.
asked Oct 5, 2022 by mightycabal (1.0k points)
I have a web view set up where the user is locked down to only seeing thier approvals. When they get a email notification, and click on the approve or deny link, ... that would grant this access but I am wondering if there is something I am missing.
asked Apr 7, 2023 by mightycabal (1.0k points)
We are in hybrid mode with 365. All the accounts we create have to made with a .com instead of .local. How can I make that change in adaxes? Or is this some default I need to change in AD instead?
asked Apr 11, 2022 by LEGIT1 (150 points)
I added the Password last set field to the Admin view but when I click on edit it allows the admin user to change the value. Adaxes correclty handel Bad Password time and Bad password ... last set, so I guest there is a way but I can not find it. Thanks you
asked Dec 19, 2019 by tomlaf (60 points)
asked Nov 7, 2023 by johanpr (80 points)
3,362 questions
7,812 comments
545,229 users
