I would like to have the possibility to use different icons for AD groups. I have groups for file permissions, applications, mailboxes, etc. For each group type I would like to assign an icon based on a property (e.g. name starts with "GSW" then show software icon).
For the report "my managed objects" it could look like this: image.png
The property fields should also be configurable depending on the AD group. E.g. with a Mail AD group the field Mail should be shown. image.png
Or for an AD group, which is used to control software, the following fields should be displayed, for example: image.png
Actually this would be possible with own object types, as it is described here: https://www.adaxes.com/tutorials_WebInterfaceCustomization_ManageADObjectsOfCustomType.htm
But, extending the AD schema is a serious step. Is there any way to do this without schema extension? or will this be possible in the future?
regards pudong
by (670 points)
Unfortunately, there is no such possibility. A single icon is dedicated for a single type of AD object. However, thank you for the suggestion. We forwarded it to the corresponding department for consideration.
I'd like to create a a custom report to show any approval requests (Approved, Pending, and Rejected) for membership in certain AD groups within our domain. These groups grant users ... " (Just In Time) in the name of the group. Is something like this possible?
asked Mar 30, 2020 by sirslimjim (480 points)
Im trying to rename "Extension attribute 1 and 2" to something legible for users. Is there a way to cahnge the dsiaply name myslef like how other attributes are done?
asked Feb 17, 2023 by raul.ramirez (210 points)
we are considering buying this product and our tests are going ok, but we have a usecase which we cannot seem to figure out. when modifying a user and that use is a member ... need to do this for a number of groups for sevices that are tied to these groups.
asked Mar 23, 2023 by i*windows (260 points)
I'm brand new to this product and am still learning, I apologize for what are presumably bonehead questions. Here goes: 1) We've got a Create Contact action set up ... the custom form Exchange-enables the group? Thanks for the information, A brand new user.
asked Oct 4, 2016 by ctdhelpdesk (190 points)
3,354 questions
7,796 comments
545,139 users
