Hi
We have a set of business rules which are used for creating new distribution lists, these rules all have the same activity scope of a number of OUs, but the number of OUs expands on a frequent basis. I was hoping to use a Business Unit which includes all of the Distribution OUs (all these OUs names end with Distribution) but the rules are applied to groups and the Business Unit is looking for OUs.
I don't believe that this is yet possible, but is it on your roadmap to allow Business Units with OUs to be used in activity scopes for other objects? It would be really useful to ensure that when a new OU is created, it's not missed from the activity scope.
Matt
by (2.0k points)
by (273k points)
Hello Matt,
It is already possible to use business units in scopes of business rules. However, that will not work for the rules triggering upon object creation. Also, the business unit must contain the type of objects the business rule is configured for (e. g. group). In your case, each OU can be specified as search base for the coresponding Query results membership rule in your business unit. image.png
I created a scheduled task (to export data) with a domain as its activity scope, runs perfectly. I modified it to use a Business Unit as its activity scope, now it ... the task effective for" should be checked, but the property is not editable in the dialog.
asked Mar 23, 2015 by sbanks (270 points)
This search script works well. Thank you. I would like to search for all scheduled tasks based on Activity Scope. I would like to delete all scheduled tasks that are ... be assigned over a specific user. What would be the best approach under this circumstance?
asked Apr 11 by Moodie007 (60 points)
Hey all, I would like to select the default computer OU as a Assignment scope for a security role. I can select every other object and OU expect this. Is there a ... I give assignments over all objects, but then they can dump the computers anywhere. Thanks!
asked Jul 18, 2018 by dennis.peabody (50 points)
Dear Support, we try to use a "Custom Business Unit" in a "Property Pattern" for excluding OUs, but it doesn't works. We created a Business Unit called "Service OUs ... Membership Rules is the following filter set: Do you know whats wrong in my Business Unit?
asked Jan 28, 2014 by Napoleon (700 points)
Is there a way to use a Business Unit as a condition of a Business Rule? There's a condition called "If an Initiator is a member of <business unit>", but not a generic ... purchased the tool, so I'm still learning and I might have missed it. Thx! --Joel
asked Apr 24, 2015 by ashmite (470 points)
3,371 questions
545,356 users
