Thank you this is the Report. Just have couple question.
I want to check a user group and only see the nested groups. Is it possible filter out the nested groups? If so, is there a parameter that can be set to display only groups from the specific OU.
related to an answer for: Nested Groups Show in Web Interface
by (340 points)
Sorry for the confusion, but we are not sure on the desired result. Do you want to select a user and see only the groups located in a specific OU where the user is a member of indirectly (groups the user is a direct member of will not be present in the report)? If this is not what you need, please, describe the desired report in all the possible details with live examples.
Hello
almost but not, what i to see is if the User member of indirectly groups is in a specific OU (of Groups). Hope i described it better.
Sorry for the confusion, but we are still not sure we understand what you need the report to contain as a result. Please, provide a live example of the behaviour you need.
I recently updated to Adaxes 2023.2 from 2021.x. We have a weekly email that goes out documenting users membership in groups and it is helpful for a historical look ... 'primaryGroupToken'." Stack trace: at <ScriptBlock>, <No file>: line 34
asked May 29, 2023 by jbadry (430 points)
Hello, I have 3 groups in my AD environment and want to show all the users that belong to each group. For example - Group 1 Group 2 Group 3 The existing report in the Adaxes ... -Usser D etc. Is there a way to create a report like this? Thank you in advance!
asked Nov 6, 2020 by sirslimjim (480 points)
Our AD Forest has One primary Domain and 4 child domains, our users are in the child domains. all of the groups are in the Primary domain(Global groups). Here is the ... the user in the primary domain and then move them to the correct domain. Any sugestions?
asked Jun 4, 2014 by babbeaw (320 points)
They can navigate to both the user or the group within the ADAXES web interface without issue. They can then either Add to Group or Add Member but the resulting ... something to the web interface which prevents changing the lookup domain. Any ideas? Thanks!
asked Apr 9, 2020 by VTPatsFan (610 points)
3,372 questions
545,358 users
