It appears that we can allow conflicting meetings on a room mailbox but can't set the number of allowed conflicts. Is this a bug or intended? Can we request this feature? Do you have a script to create a custom command for this?
We are on version 3.14.19723.0
Thanks, Mark
by (2.3k points)
by (304k points)
Hello Mark,
This behavior is by design.
We forwarded the request to the corresponding department for consideration.
You can use the below script. In the script:
  • $exchangeServer – Specifies the host name of the Exchange server.
  • $numberOfConflicts – Specifies the number of allowed conflicts to set.
$exchangeServer = "exchangeServer.domain.com" # TODO: modify me
$numberOfConflicts = 3  # TODO: modify me
    # Connect to Exchange server
    Import-PSSession -session $session -CommandName "Set-CalendarProcessing"
    # Change mailbox type
    Set-CalendarProcessing "%distinguishedName%" -MaximumConflictInstances $numberOfConflicts
    if ($session) { Remove-PSSession -Session $session}
We would like to auto enroll our entire company into Adaxes for self service but do not want to use the question/answer format but instead their phone numbers (provided by HR department). Is this possible? Best, Evangelos
asked Oct 1, 2021 by evangelos (60 points)
We have 4 om prem servers to setup Adaxes on, we currently have almost everything on one server but have crashed on several occassions when multiple scheduled jobs are ... way to achieve this configuration without having to buy double the licenses. Thanks' Jay
asked Sep 24, 2021 by willy-wally (3.2k points)
asked Jul 22, 2021 by jtop (700 points)
Hello, Is it possible to grant members of a business unit permission to run a custom command? I know I'm able to give permission to a user/group to run a cmd on a business ... that can run the command. I've not been successful with any of my attempts to do so.
asked Mar 23, 2017 by JoCCCsa (100 points)
3,717 questions
8,592 comments
549,984 users
