I recently set up a business role per a post in this thread that creates an on-prem shared mailbox and then moves that mailbox to O365. The issue is that the powershell script to move to O365 keeps erroring out with the following:
Connecting to remote server failed with the following error message: WS-Management cannot process the request. The operation failed because of an HTTP error. HTTP error 12152: server returned an invalid or unrecognized response.
I pulled the script straight from Adaxes support so not sure where it went wrong. The script I grabbed is below (took out variables specific to our environment):
Taken from this forum post: Create user mailbox in Office 365?
# Credentials of a user who has sufficient permissions to provision users for Office 365
$office365AdminName = "removed_for_post" # TODO: modify me
$office365AdminPassword = ConvertTo-SecureString -AsPlainText -Force -String "removed_for_post" # TODO: modify me
$office365DeliveryDomain = "removed_for_post" # TODO: modify me
$office365Credentials = New-Object -TypeName System.Management.Automation.PSCredential($office365AdminName, $office365AdminPassword)
$session = New-PSSession -ConfigurationName Microsoft.Exchange -ConnectionUri "https://ps.outlook.com/powershell/" -Credential $office365Credentials -Authentication Basic -AllowRedirection
Import-PSSession $session
# Credentials of the local Exchange domain administrator
$localAdminName = $Context.RunAs.UserName + "@" + $Context.RunAs.Domain
$localAdminPassword = ConvertTo-SecureString -AsPlainText -Force -String $Context.RunAs.Password
$localAdminCredentials = New-Object -TypeName System.Management.Automation.PSCredential($localAdminName, $localAdminPassword)
$localDomain = $Context.GetObjectDomain("%distinguishedName%")
    $result = New-MoveRequest -Identity "%username%" -Remote -RemoteHostName $localDomain -TargetDeliveryDomain $office365DeliveryDomain -RemoteCredential $localAdminCredentials -ErrorAction Stop
Remove-PSSession $Session
if ($result -ne $NULL)
    $Context.LogMessage("Mailbox move request created successfully. Check Exchange logs for details." , "Information")
by (480 points)
Nevermind, this has been RESOLVED. For whatever reason, in our environment, the call to O365 will error out the first try every time. We put a loop in to try it twice and it worked.
Hello, We have an exchange server in a separate forest. When we create the mailbox using a business rule after user creation, the mailbox creates ok. After the user ... multi-forest environment and it made no difference. Thanks for any help you can provide.
asked Nov 2, 2018 by Jasonmh (540 points)
I am having an issue running a powershell script through Adaxes. I am trying to have this run as a business rule when ... $optoffice.DisabledServicePlans = "ONEDRIVESTANDARD" Set-MsolUserLicense -UserPrincipalName %userPrincipalName% -LicenseOptions $optOffice
asked Mar 2, 2015 by malsobrook (50 points)
Hi there, i've a custom command with multiple powershell scripts (for clearance reasons). If for example the frist script produces an error i Write an Error but the next ... tried with an simple exit 1; I only Write-Errors on issues. Kind regards, Constantin
asked Jul 23, 2021 by Constey (190 points)
asked Aug 1, 2023 by curtisa (210 points)
3,388 questions
7,850 comments
545,573 users
