after upgrading to Adaxes 2023 we lost connection to Web Interface Configurator. Adaxes and Adaxes Web Interface are ok and users are able to login.
URL http://xx.xx.xx/AdaxesConfig/ gives error "Fatal Error" and tells Request parameters are invalid or missing.
Upgrade was done by backing up, uninstall Adaxes, install Adaxes and then restore. That went ok except I had to start manually Softerrra Adaxes service after restoring settings.
by (210 points)
For troubleshooting purposes, please, provide us with a screenshot of the error including the browser address bar. You can post the screenshot here or send to us at support@adaxes.com.
Screenshot sent by email.
Hello, I get this error after logging into the web interface (As Adaxes Admin):   Fatal Error - Cannot process the request because the request signature is invalid or ... Adaxes Services/Server about 3 or 4 times now and restarting the computer as well.
asked Feb 6, 2023 by Edogstraus00 (470 points)
When I tried to login to web interface configurator it ask the username to be UPN (username@domain.com). If I just type SAM (username) it gave warning that username is not valid. Can we enable just to use username ?
asked Nov 22, 2021 by fachmi (170 points)
After updating from 2020.1 to 2021.1, my IIS keeps throwing a 404 not found error when attempting to access the Web interface configurator. I'm thinking that the path could be wrong or something could be missing?
asked Mar 9, 2021 by blauprgy (20 points)
We've uninstalled the previous version via the "add/Remove Programs" feature in Windows 10, but we still get an error saying that another version of the client is still installed and won't allow us to run the .MSI installer. How can we get around this?
asked Feb 15 by MShep (80 points)
545,391 users
